Here is the information I have found regarding the 6 speed swap, I am focused on the 1.9 pre-facelift T5, though the T5.1 with the 2.0 will be similar.
At the moment I am 90% there, I’ve got the parts and I’ve mocked up my engine block to the gearbox, but I haven’t got to the point of fitting the engine and ‘box to the van, so there are a couple of things I’m concerned about which I’ll get to later.
Why do it? I use my van for everything, I do 500+ a month, mostly on the motorway so I want to be able to cruise at lower revs for MPG and less noise. Also the stock 5 speed clutch is apparently only good to 170bhp/300ftlb, and when I was looking there wasn’t an off-the-shelf uprated clutch. The gearbox is apparently good for 200bhp/330ftlb.
Why shouldn’t I do it? Cost! The gearbox alone was over £1k, the clutch and flywheel cost over £700. That’s without all the other parts I’ve had to buy and I’m just ignoring. I should have just saved my money and bought a T5.1 with the 6 speed already, but personally I love the PD engines, and I enjoy a project. So, I am doing it and I have already spent the money.
As per my last post the Darkside page covers most of this. Parts required;
0A5 Gearbox from a T5.1 2L diesel, codes: KUP, MKB, MQX, PAP, PAT, PAU, PAV, NTF. These were fitted to the 136 (CAAE or CCHB), 140 (CAAC or CCHA) and 182 (CFCA) bhp vans. I’ve got the MQX.
You can NOT easily use the 6 speed from the 2.5L T5 as the bellhousings are a totally different bolt pattern, and I have no idea if the clutch/flywheel would mount up to the engine. Maybe its possible with an adapter plate? But it would be a shed load of work and not, IMHO, worth it.
Clutch and flywheel; Sachs dual mass flywheel 2294 002 165, Sachs SRE pressure plate P/N 883082 001394, Sachs SRE organic friction disc P/N 881864 002540 (rated to 407 ftlb), Sachs concentric release bearing P/N 3182 654 150. It was much cheaper to shop around searching by Sachs part number, I got the flywheel, pressure plate and release bearing from AutoDoc and the friction disc from fleabay for all-in around £760, vs Darkside who want £1008. You will also need the 2L 6 speed starter motor.
Gear selector cables; these are specific to the 6 speed, make sure you get the cable mounting bracket either with the gearbox or the cables.
Try to get the bellhousing bolts with the gearbox, I didn’t, I’ve had to buy the special double ended studs from VW (not too expensive) and the rest I am using 12.9 socket cap bolts and thick washers.
You will also need the thin sheet metal cover plate which gets sandwiched between the block and the bellhousing, Darkside didn’t mention that one…
As in my last post I had to modify one of the engine block mounting points, as it fouled the gearbox next to the driveshaft. Now this might be specific to the ASZ, I’m just glad I found out before I built the engine!
Driveshafts; both are different to the 5 speed, I bought new SKF ones from AutoDoc tho you could get second hand ones from fleabay. The support bearing for the driver side driveshaft is in a different position which means you have to modify the engine mount.
Engine mount; The rear engine mount on all T5’s (and T4’s) have a mount for the drivers side driveshaft carrier bearing. But its in a different position on the 1.9 to the 2L. The 2L mount doesn’t mount up to the ASZ engine for sure (I bought one to try) and I don’t believe it fits the BRR/BRS either.
I used pictures in Shaun L ‘s thread as a guide (link in my engine post). Darkside now sell the mount already modified for an eye-watering £420, or they can modify your mount for £240. This wasn’t available when I started so I’ve done it differently, but I do think their solution is better than mine.
Mocking up and marking out the 1.9 engine mount:
Cutting out for clearance, I then welded material back in to close off the cut-out:
Machined block bolts to original mounting holes (no bearing mounting holes drilled yet):
Bolted back up to the mocked-up engine:
Inside the mount is a machined steel spreader plate to help support the aluminium block, probably overkill but I’m not overly happy with my aluminium welding:
