This is a little write up to help others with this fault.
The fault will most likely start as random erratic illumination of the ABS and traction control lights, and if the fault codes are read, will show as- (Or 00290 G46 rear left)
Address 03: ABS Brakes Labels: 7H0-907-37x-ABS.clb
Control Module Part Number: 7H0 907 379 S HW: 7H0 907 379 S
Component and/or Version: (M)ABS MK25E 0103
Software Coding: 0000552
Work Shop Code: WSC 02736 790 00000
VCID: 45D4587249BD3103004-5160
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 9
Reset counter: 40
Mileage: 179182 km
Time Indication: 0
Freeze Frame:
Count: 2176
Count: 12545
Count: 80
Count: 0
The first test is to check the voltage at the sensor plug, it should be 11.5 - 12 V. Anything less than 11V and there is a problem in the wiring.
The second test is to find the brown plug under the passenger seat, which carries the 2 rear sensor wires, and check the voltage here. If all is good, then the fault is very likely at the bottom of the D pillar where the sensor cable is spliced into the loom.
This is a reasonably easy job to do-
Wheel off.
Wheel arch liner out (4 torx screws, 1 x 8mm screw, 1 x 10mm bolt, 1 spring washer, 1 spring clip)
Unclip ABS cable from behind arch - no need to disconnect sensor.
Remove rear light.
Prise out cable grommets and find small cable that goes downwards.
Push ABS cable grommet into the body, and pull out cable loop from rear light hole, carefully feeding in the cable clips. See large loop-
Very carefully slice open the loom where it changes diameter, and locate 2 crimp connectors in plastic sleeve, one of them will probably just fall apart and be green and corroded-
I cut both wires, soldered them together with heat shrink sleeve, taped up the loom, tested the voltage and cleared the codes-
Job done! 😀😀😀
Couple of edit additions-
G44 rear right speed sensor are brown and black wires at the brown plug under the passenger seat.
G46 rear left speed sensor are green and black wires at the brown plug under the passenger seat.
On my van, the brown plug has 5 wires, the 4 together in a square are the sensors.
The plug is located behind 2 covers in the middle of the passenger seat base (lift up a double seat, or look under a fixed single seat)
The loom below the D pillar is wired the same both sides, ie the loom drops from the roof, and the last cable going down past the rear light is the sensor cable.
I was expecting to see damp where this cable had failed, but it was dry as a bone, although there must have been some moisture in the joint, as it had electrolyzed and dissolved the cable, hence the green sludge.
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 40
Mileage: 179182 km
Time Indication: 0
Freeze Frame:
Count: 2176
Count: 12545
Count: 80
Count: 0
Wheel off.
Remove rear light.
Job done! 😀😀😀
