My T5 rear sliding door is definetly shut yet the alarm on the dash is on and BEEPING. The central locking system works except that when locked the red LED on the drivers side door is not on, due to the sliding door sensor not registering that the door is closed (I assume). The sliding door has an electric motor in the door that when the handle is lifted the door opens.
Since this fault, it appears that there is no power to the door. I have used a multimeter to check for voltage at the door contacts and found no supply. I have checked all fuses & found all OK.
Can anyone assist?
Can anyone assist?
