1 - 10 of 10 Posts
Hi Folks,
Was wondering if anyone could offer some advice on where to purchase a good T.V. bracket for a T5 / T5.1. I have viewed a historic post from around 4 years ago, and have tried to make contact with the author, but am still waiting for a reply.
Many thanks
Want Electrics? Go Wildebus!
Yes the "B" Pillar where the seat belts are mounted, I've seen loads mounted there its behind the headrest positioned against the wall until required for use, then swung out.
That is where mine is fitted T:
I used the same mounting points that the B Pillar Grab Handles uses (see post here ==> http://www.vwt4forum.co.uk/showpost.php?p=4601474&postcount=144) with an off-the-shelf TV mounting kit.
Works very will I think. Not sure if the B Pillar grab handle is on both sides of the single door T5s though?
Transporters don't have b pillar grab handles as standard you would need to get the brackets for these too if the op is fitting into a transporter but like the idea will be copying this once my pop top is fitted.
1 - 10 of 10 Posts
