I must admit I'm not surprised at their records not accurately reflecting was was fitted to your van - there seems to be no logic behind which vans get full undertrays and which don't. Got to agree that there doesn't seem to be much attention to detail going on there, though.
As a matter of interest, what were your blower/distribution problems? Mine's throwing up error codes for the dash air control flaps and I was wondering if it was related.
They couldn't fail to notice the guards if they looked underneath. It's rather sad they didn't notice. Will find out their reasons tomorrow. You're probably better not to have them tbh as mine fell off anyway.
Yes the symptoms you have are precisely what I had, I have vcds.
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaticT5.rod
VCID: 7BFFE935F2FE411
3 Faults Found:
9473905 - Motor for Temperature Flap
B108F 71 [008] - Actuator stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 93
9474161 - Motor for Defroster Flap
B1090 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
9581681 - Positioning Motor for Front Footwell Air Distribution Flap
B1234 71 [008] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
