Hi
Just had our units fitted and over the moon. One thing we just noticed that might be wrong is the table rail fit. It has the middle stability adaptor part upside down? It still grips on to the table but the lever part is facing down. See pic below as an example from google.
This stability part is not yet screwed in and the rail is a bit too high on the units for this part to be turned around. How essential is it? If we do need to turn it around, then will have to lower the rail about 1cm down too. Thanks
191861
191863
191862
That is correctly fitted, it's spring loaded and acts as a locator/anti rattle device
Picture of ours below
Sent from my G8141 using Tapatalk
As you say... Hmmm... Looks like both of ours have been fitted a**e-about-face!
Nevertheless works just as well as I tried the table upside down and there is hardly any difference either way
thought it might be the case, thanks. Now just need to trim the table down a bit. Measure twice, cut once as they say..
hope you meant to trim the leg and not the table..
Good luck...
