1 - 10 of 10 Posts
hi all, can anyone tell me where the interior light switch is located for the rear door(up and over).it was working a couple of days ago, but doesnt now.all the lights come on when any of the over doors are opened.
cheers
grum
Had same issue with mine.
One day it worked and the next it didnt.
I unplugged the connector and gave everything a regular coating of wd40 for a week this sorted the problem.
Check the two wires on the plug that goes into the mechanism. They come through the tailgate bodywork at a very tight angle and may have been pinched or snapped.
when you say the mechanism, do you mean the catch mechanism or the actual lock mechanism mounted behind the number plate. ive chased the wires from the light and as far as i can see they run up the door and out at the top o/s corner.I musr have missed a spur somewhere, as the light was fading.
cheers
grum
The catch mechanism on the bottom edge of the tailgate. You should just about see two tiny wires poking out.
The switch itself is a small microswitch in the tailgate catch. It tried to remove mine but couldnt get it out.
As usual, WD40 is the solution to all problems.
:ILU:cheers again, thought it was the catch mechanism. will have another go tomorow.
Happy new year to you all.
1 - 10 of 10 Posts
