I have a 1996 2.4 5 cylinder diesel, She drives super but on tickover I here a tapping sound like a tappet , do you know what this migt be?????
Also can you give me a rough ider on the cost of changing the cam belt, the motor has done 76,000 in the service book it says the belt was changed at 62,000 but can you be sure of this????
Thankyou.
ps just got the van.
Hi irish. We have the same noise & apparently if you push hard on brake pedal & noise stops, but then comes back again, it's the vacuum pump. Nothing to worry about immediately tho T:
If noise goes away when brakes pressed it is indeed the vacuum pump.
You can replace the little rod in the vacuum pump. If you get it early enough this will cure the problem, if not you will have to replace the whole pump.
Rod is about £25-£30. pump about £180-£200
Easy enough to do, you have to remove the pump. 2 bolts one of which is dificult to take off. Replace rod and use grease to hold it in place when reassembling.
Good idea to replace seal seal when doing this job.
Hope this helps.
Well Lads ,Thats a load off my mind,
Yes Yes it does go away when you bress brakes. Thankyou for your prompt replys,A:T:
