any of you that have swapped the TD to TDi and are showing a Baromtric pressure sensor fault on Vag com dont worry about it.
it turns out that the early TDi had a seperate sensor - the later ones are fitted in the ECU along with the immob.
this sensor does nothing until you are above 3000 ft so for UK use and most of Europe its not required and it does so little above 3000 ft that you dont miss it if it is missing.
Info came via an auto electrician who has a very good friend that works for VAG MK technical.
