1 - 11 of 11 Posts
hi one for the tdi converts or auto electricians
ive conversted my 800special to tdi 1z engine from a passat
ive put all the engine loom in and the imobilizor from the passat but still no go
it starts and runs for around 20seconds then conks out,
also with it running for the 20secs it does) if i turn the throttle pot it wont rev at all
all in all im gutted and if any1 would be willing to ave a look for me or avise me in the right direction
thanks ian
Hi Ian
Blimey mate, sounds like you been busy, I would think your first move is to get it plugged into a computer and someone run a diagnosis.
I should try searching the Engine section, lots of conversions there, or maybe give Stridey a shout as he has done an Audi engine in his ... best of luck
Jimbo
ive pm'd aggiest4 but i dont think hes interseted
pdubby is being a great help but im still struggling
Meithered to death
aggiet4's has been on holiday and hasnt had a pm from mini boy ian lately,maybe you are sending them to aggiest4 like you said,your problem sounds like a transponder issue but its probably sorted by now :cool:
Transporter Tuning Specialist
thanks ian
Ian,
Sounds like you have an immo fault. Best bet would be to have the immo deleted from the ECU.
Regard
Martin
Discussion Starter · #8 ·
hi guys im still having problems
has anyone done the tdi conversion in the south west? i would be soooo gratefull if i could have a nose around their van wiring or be able to give me a hand for a few beer tokens
cheers ian
sound like your immobiliser is still activated . i dont know how to deactivate it myself but its suppose to be a easy enough job . try posting in the engine section you might get more response T:
u need the transponed, control unit, and woring from the passat, and the transponder from the passat key. Put this transponder inside ur current t4 key, and it should all be ok?
Failrly easy tbh.....u just need the passat immob loom
Discussion Starter · #11 ·
trust me ive tryed everything its been 8 weeks now of not having the van im so tempted to get rid its getting on my
1 - 11 of 11 Posts
