Hi guys I'm doin a tdi convertion on my 96 1.9td how do i get the speedo to work as it's the fly by wire type and the wire is removed with the engine loom Tia
rusty heap ('95 t4)
the tdi engine loom usually has a (3 wire) socket connected to the speed sensor that is on the speedo drive, should be connected through t he main loom to the fusebox??
sometimes they need the wiring extended to fit the van as the engine leans differently to the car (had to do on my '95 T4 using a B4 passat as donor, done a few others with mk3 golf donor's that were long enough)
Rich.
