1 - 11 of 11 Posts
Not as easy as YouTube makes out, first time I ever did it with a bit of help from my mate Bob. Only advice I can give is read the build threads, read more and have the right tools. First window was a struggle but the second was far easierT:
Hi , good job!
Can I ask where you got the glass for your van and the cost, just about to start a conversion myself.
Thanks in advance
Jason
Sorry for hijacking, Great job on the windows by the way, I can confirm also that I found it a little harder than youtube suggested.
I used a jigsaw, and just kept changing the blade and taping the cut every so often to help minimise the vibration. I found the jigsaw to be very neat. I didn't read the instructions enough thought as I spent a lot of time making the initial cut perfect where there is another cut inline with the internal frame after - so I got demoralised very quickly!!
Also - I panicked when applying the bonding, it was taking a lot - and I mean hand cramping amounts of effort - to get the damned stuff out of the tube! it took me ages just to line the bottom of the window so I panicked thinking its going off and shoved the window glass on - and guess what ... it leaks (no surprise)
But I'm much more optimistic on getting the second window correct and I'm going to obviously remove this one and redo it.
1 - 11 of 11 Posts
