Gear selection in the Transporter is relayed by heavy duty rods rather than cables and the final drive casings are enlarged to house a bigger - and stronger - crown wheel and pinion.
The Transporter clutch is either actuated hydraulically by an externally mounted slave cylinder (on all rhd vehicles, all vehicles with additional heater and all vehicles destined for Canada) or mechanically by a self adjusting cable.
This range of gearboxes was fitted from launch right across the T4 range on all models bar the TDI, TDI, VR6 and Syncro models:
1) Gearbox Data for the 2.5 TDI
Clutch Diameter
- 2.5 TDI AJT, AYY 219mm (with twin mass flywheel)
- 4.235:1 (common to all)
- reverse gear 3.600:1
- speedometer drive 0.600:1
- 1st gear 3.778:1
T4b Caravelle
DUJ, EWB
- 2nd 2.118
- 3rd 1.304
- 4th 0.903
- 5th 0.700 (28:40)
- Overall Ratio in 5th gear (final drive x 5th gear) 2.965:1 = Theoretical Road Speed @ 3,000 rpm 78mph (126km/h)
DUH, EWA
- 2nd 2.063
- 3rd 1.348
- 4th 0.967
- 5th 0.744 (29:39)
- Overall Ratio in 5th gear 3.150:1 = Theoretical Road Speed @ 3,000rpm 74mph (119km/h)
T4b
- 06.98 W X Y 1 (to 08.00) DUH, DUJ
- 09.00 1 2 3 EWA, EWB
Clutch Diameters
- 1.9 TD ABL 215mm
- 2.4 D na AAB 215mm
- 2.4 D na AJA 219mm (with twin mass flywheel)
- 2.5 Petrol AAF, ACU, AEN, AEU 228mm
- 2.5 Petrol AET, APL, AVT 228mm
- 4.941:1
- 4.611:1
- 4.563:1
- reverse gear 3.600:1 18 tooth gear (3.800:1, 19 tooth - AYD,AYF)
- 1st gear 3.778:1
T4a Caravelle Multivan
AYF, CCX*
- 2nd 2.118
- 3rd 1.360 (1.345 - AYF)
- 4th 0.971
- 5th 0.756 (34:45)
- Final Drive 4.941
- Overall Ratio in 5th Gear 3.735:1 = Theoretical Road Speed @ 3,000rpm 62mph (100km/h)
- 2nd 2.118
- 3rd 1.360
- 4th 0.971
- 5th 0.756 (34:45)
- Final Drive 4.611
- Overall Ratio in 5th Gear 3.486:1 = Theoretical Road Speed @ 3,000rpm 66mph (106km/h)
- 2nd 2.063
- 3rd 1.348
- 4th 0.967
- 5th 0.769 (30:39)
- Final Drive 4.563
- Overall Ratio in 5th Gear 3.509:1 = Theoretical Road Speed @ 3,000 rpm 66mph (106km/h)
AYD, CCW, CHP, CRL
- 2nd 2.118
- 3rd 1.458 (1.429 - AYD)
- 4th 1.029
- 5th 0.837 (36:43)
- Final Drive 4.611
- Overall Ratio in 5th Gear 3.859:1 = Theoretocal Road Speed @ 3,000rpm 60mph (97km/h)
- 2nd 2.063
- 3rd 1.455
- 4th 1.034
- 5th 0.838 (31:37)
- Final Drive 4.563
- Overall Ratio in 5th Gear 3.824:1 = Theoretical Road Speed @ 3,000 rpm 61mph (98km/h)
DJZ, DQL, EVY
- 2nd 2.118
- 3rd 1.360
- 4th 0.971
- 5th 0.756 (34:45)
- Final Drive 4.611
DCW, DQH, EVW
- 2nd 2.063
- 3rd 1.348
- 4th 0.967
- 5th 0.769 (30:39) 0.744 (29:39) - DQH, EVW
- Final Drive 4.563
- Overall Ratio in 5th Gear 3.509:1 = Theoretical Road Speed @ 3,000 rpm 66mph (106km/h) 3.395:1 - DQH, EVW = 69mph (111km/h)
DKA, DQM, EVZ
- 2nd 2.118
- 3rd 1.458
- 4th 1.029
- 5th 0.837 (36:43)
- Final Drive 4.611
- Overall Ratio in 5th Gear 3.859:1 = Theoretical Road Speed @ 3,000rpm 60mph (97km/h)
- 2nd 2.063
- 3rd 1.455
- 4th 1.034
- 5th 0.838 (31:37)
- Final Drive 4.563
- Overall Ratio in 5th Gear 3.824:1 = Theoretical Road Speed @ 3,000rpm 61mph (98km/h)
T4a from:
- 01.90 L M AYD, AYF
- 08.91 N CCW, CCX*, CCY
- 08.92 P CHP, CHS (1.9 ABL launch)
- 08.93 R (to 12.93) CRL, CRN
- 01.94 R (from 01.94) S T (to 12.95) CPV, CPW
T4b from
- 01.96 T V (to 04.97) DCU, DCW, DJZ, DKA
- 05.97 V W X Y 1 (to 08.00) DQG**, DQH**, DQL, DQM
- 09.00 1 2 3 EVU**, EVW**, EVY, EVZ
3) Data for 1.9D na, 1.8 and 2.0 Petrol models
Clutch diameters
- 1.9 D na 1X 215mm
- 1.8 petrol PD 228mm
- 2.0 petrol AAC 228mm
- 4.941:1 (common to all)
- reverse gear 3.600:1 (3.800:1 - AYE, AYG)
- 1st gear 3.778:1
- 2nd gear 2.118:1
T4a Caravelle
AYE, CCX*, CHR, CRM
- 3rd 1.360 (1.345 - AYE)
- 4th 0.971
- 5th 0.756 (34:45)
- Overall Ratio in 5th gear 3.735:1 = Theoretical Road Speed @ 3,000rpm 62mph (100km/h)
AYG, CCZ, CHT, CRP
- 3rd 1.458 (1.429 - AYG)
- 4th 1.029
- 5th 0.837 (36:43)
- Overall Ratio in 5th gear 4.136:1 = Theoretical Road Speed @ 3,000rpm 56mph (90km/h)
DCV, DQJ, EVV
- 3rd 1.360
- 4th 0.971
- 5th 0.756 (34:45)
- Overall Ratio in 5th gear 3.735:1 = Theoretical Road Speed @ 3,000rpm 62mph (90km/h)
DCX, DQK, EVX
- 3rd 1.458
- 4th 1.029
- 5th 0.837 (36:43)
T4a
- 01.90 L M AYE, AYG
- 08.91 N CCX*, CCZ
- 08.92 P CHR, CHT (1.8 PD engine dropped)
- 08.93 R S T (to 12.95) CRM, CRP
T4b (2.0 AAC engine only)
- 01.96 T V (to 04.97) DCV, DCX
- 05.97 V W X Y 1 (to 08.00) DQJ, DQK
- 09.00 1 2 3 EVV, EVX
To sum all this up - Caravelles have economy / touring gearboxes; Transporters have sports / close-ratio gearboxes for maximum torque multiplication (pulling power) at the expense of overall speed and economy (whichever way you wish to look at it)...
Footnote - Gearbox Mounting Differences
T4a Early Gearbox Mountings
T4b Late Gearbox Mountings (including 02G types)
