The Audi based ACV engine was initially the most powerful engine installed in the T4, but the 02G gearbox paved the way for even more potent engines - the 111kw (150bhp) TDI and the VR6 narrow angle petrol engines.
The March 1998 introduction of the TDI Syncro saw the first use of the 02G gearbox in the four wheel drive models.
Clutch Plate Diameters
- 2.5 TDI ACV, AUF, AYC, AXL 219mm - twin mass flywheel
- 2.5 TDI AHY, AXG 240mm - twin mass flywheel
- 2.8 VR6 AES 219mm - twin mass flywheel
- 2.8 V6 AMV, AXK 4-speed automatic only
- 3.905
- 3.944
- 4.933
- reverse gear 3.700
- speedometer drive 0.591 (electronic speed transducer on TDI / TDI Syncro)
- 02D Rear Differential 1.000 (1:1 direct drive TDI Syncro only)
TDI
AFK (inc T4a from 08.95), DXZ, EME, FJS
- 1st 3.909
- 2nd 2.118
- 3rd 1.346
- 4th 0.972
- 5th 0.729
- Final Drive 3.905
- Overall Ratio in 5th gear (final drive x 5th gear) 2.847:1 = Theoretical Road Speed @ 3,000rpm 81mph (130km/h)
DRH, EFA, FTV*
- 1st 4.300
- 2nd 2.313
- 3rd 1.346
- 4th 0.868
- 5th 0.627
- Final Drive 4.933
- Overall Ratio in 5th gear 3.093:1 = Theoretical Road Speed @ 3,000rpm 75mph (121km/h)
VR6
AFL, DYA
- as per TDI
DQR, EEZ
- 1st 3.909
- 2nd 2.118
- 3rd 1.296
- 4th 0.895
- 5th 0.694
- Final Drive 3.944
- Overall Ratio in 5th gear 2.737:1 = Theoretical Road Speed @ 3,000rpm 85mph (137km/h)
- 08.95 T V W AFK*(TDI), AFL*(VR6)
- 03.98 V DRH***(TDI Syncro)
- 05.98 V W X EEZ**(TDI)
- 08.98 X Y 1 DXZ*(TDI), DYA*(VR6)
- 08.98 X Y 1 (to 02.01) EFA***(TDI Syncro)
- 07.99 X Y 1 2 3 DQR**(TDI)
- 03.01 1 2 3 EME, FJS (TDI), FTV (TDI Syncro)
** the TDI gearbox has uprated input and output shafts and an uprated final drive
*** TDI Syncro gearbox with drive to 02D rear axle (see below for options)
02D Rear Differential Options (with 100mm driveshaft flanges)
- Differential Lock with ABS and Freewheel DUB, DTZ
- Differential Lock only DUA
- ABS and Freewheel only DTY
Gearbox Mountings
