1998 TD (aaz conversion so no ecu)
I have the fault where the instrument panel resets itself every now and then. The speedo, temp, fuel and trip counter die then come back on. It started with just the fuel guage. Then it got a bit worse. Now its becoming more frequent.
From what I have read its a cracked soldier joint in the current regulator, all the repair guides I've seen are for full analogue clusters
I have no worries about removing the panel and reparing the board. However my model dash is the analogue clock with a digital trip counter / mileage. No rev counter (diesel) I'm not sure if the guides apply? Anyone know
Also - if the panel dies will I be able to start and drive the van. I'm using it a lot and have the nagging anxiety of being stranded. I've got aux instruments for oil temp and boost. Plus a satnav for speed as long as the damn thing runs!
Also I've herd of wiring faults, could it be an old wire?
Any help and reassurance would be appreciated
