Hi All,
My T4 like very many others has the coolant level light on permanently. I'm about to do a VAGCOM check but here are the possible issues that the light could be caused by......and the solutions that people have found. It seems that there are many causes of the problem.
Sensor in Expansion Tank - http://www.vwt4forum.co.uk/showthread.php?t=69604
General Connections - http://www.vwt4forum.co.uk/showthread.php?t=5035
Genuine Coolant Leak - http://www.vwt4forum.co.uk/showthread.php?t=104582
Coolant needs topping up - http://www.vwt4forum.co.uk/showthread.php?t=91349
Bad earth on the Loom - http://www.vwt4forum.co.uk/showthread.php?t=104641
Coolant pressure - http://www.vwt4forum.co.uk/showthread.php?t=98853
Cracked Expansion Bottle - http://www.vwt4forum.co.uk/showthread.php?t=104641
Solder the PCB (Analogue Clocks) - http://www.vwoc.euromarques.com/technical/tales_from_the_toolbox/t4_gauges.htm
the Bible on Clocks - http://www.vwt4forum.co.uk/showthread.php?t=86937
Degrease the Expansion Bottle - http://www.vwt4forum.co.uk/showthread.php?t=85866&page=2
A broken (very small) wire on the alternator - http://www.vwt4forum.co.uk/showthread.php?t=49381
Apart form trying the soldering the clocks solution I have checked and double checked everything. I'm gonna do a VAGCOM and see if that points to the clocks issue.
The question is does anyone else know of any other reasons why the persistent little git of a red light just wont go out.
- Dice
- Dice
