281 - 297 of 297 Posts
Just read this from start to finish.............Awesome !
Top job and lots of tips for everyone if needed.
Awesome !T:T:T:T:
Great job mate! T: Always good to see someone do most of the work themselves. :) Love the vinyl wraps. Did they use a clear vinyl with the image printed on top? Looks sweeeeeeeeeet!!! A:
slight door pocket mod...
[/QUOTE]
what did you use to cut the door pocket down?
I'm about to do the same thing as had to lower the bases (im 6foot 4) +want to keep the pockets and add speakers, but want a nice clean finish!
Discussion Starter #290
Few updates...
swivel out table leg..
Loaded it up to see what kind of weight it would hold....22.5KG on this..
Also spent all weekend under the van, had a 3rd gear selection problem so had a spare box checked over (DQL) from a 2000 1.9TD and fitted 0.65 5th gear....
Swapped over with my 95' CRN ratio box, only problems was i needed the rear mount from the later box to replace my early mount....
Running sweet as!!!!T:
Discussion Starter #296
Little update and a few changes...
lick of paint on the stove..
And a cupboard face lift
New switch panel..
And a bonnet strut cos its easier and spends soo much time open!!!
ive also been plagued with gearbox issues.. the DQL diff failed so had my original CRN rebuilt and refitted, sadly last month that died again, 2nd synchro was shot and the spring clips in the hubs on all gears had failed, 2nd hand unit i got was just as bad..so again had mine rebuilt and refitted with 0.65 ratio 5th..stuck a VR6 clutch in too..T:
