Anyone fitted a heat exchanger for hot water to a webasto thermotop? If so how did you do it? Where did you put it? I am hoping to fit one to my factory thermotop on my caravelle exec under the van somewhere if possible.
Thanks Neil.
I have been thinking about it and have come to the conclusion that using a heat exchanger with the factory fitted thermotop on our van could be a really bad idea as the heat exchanger will almost certainly reduce flow rates.
My solution is that when the time comes I am going to replace all my tyres with run flats and utilise the spare wheel space under the van to fit a second hand thermotop and heat exchanger (inside a protective box) for my hot water.
