Hi...
Wondering if anyone would have any suggestions on this one. I have a 1996 1.9TD T4 and it has a throttle lever. I don't use it all that much but I have only had the van on the road for about 2 weeks. It has been off the road for around 3 years so I have been putting fuel aditivies in to the tank to clean it up. Each morning when I start it up it runs a little crappy for about 5 seconds and then runs fine afterwards. Not entirely sure why, anyway, if I pull the throttle out a little it seems to sort the problem. I can put it straight back in after the crappy start up. Today however I pulled it out a bit too far accidentally and I am struggling to get it back in. I thought I would maybe just pull it the rest of the way out to see if it would slide back in but this didn't help. It seems to go back in a tad bit but no further.
Has anyone got any suggestions? I will be honest, diesels are not my strongest point, but from what I can see the throttle cable connects to the pump and there is a little connection on the pump that is pulled by the throttle cable. My guess could be that or possibly a seized cable (if that is possible!)?
Any help would be gratefully appreciated!
Thanks! T:
Thanks! T:
