Looking at VAG COM I get this fault:
Address 02 -------------------------------------------------------
Controller: 098 927 731 AB
Component: AG4 Getriebe 098 1687
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00660 - Kickdown Switch/Throttle Position Sensor
27-10 - Implausible Signal - Intermittent
I've been through lots of things
  • Cleaned the throttle body
  • Cleaned all earth points in engine bay
  • New distributor cap and arm
  • Swapped the ISV for a secondhand one
  • Replaced relay 167
  • Replaced the throttle sensor
I'm now wondering if it's a worn wire somewhere.
My question is, are there common places to look?
Taking the wiring loom out looks like a massive job and hacking into the protective conduit at random doesn't seem like a great idea.
Any advice?
Hi, did anyone get to the bottom of this? Just had the same fault, had the TPS replaced and still going in to limp mode and showing the same fault :(
I finally got around to finding a tiny garage that is willing to spend some time on an intermittent fault.
It will be going in this week or early next week hopefully so I'll let you know the result.
Full of Cr*p....
Like it says in big letters at the top of the forum...Always say what year/engine/etc.
Obviously, if you have changed the distributor cap, it must be a petrol.....but it's easier for people to answer if they know what vehicle they have to think about T:
Good point! I normally put that info in!
It's a 95 petrol, automatic 2.5l, LWB, 5 cylinder, engine code ACU.
I got these faults and I also suspect there's a worn wire somewhere.
Control Module Part Number: 098 927 731 AA
Component and/or Version: AG4 Getriebe 098 1517
Software Coding: 00000
Work Shop Code: WSC 00000
VCID: 60B32383F35B
3 Faults Found:
00660 - Kickdown Switch or Throttle Position Sensor
00300 - Transmission Fluid Temp. Sensor (G93)
34-00 - No Elaboration Available
00641 - ATF Temperature
06-10 - Signal too High - Intermittent
I suspet it's worn wires since the Sensor G93 is mounted ON the internal wiring harness of the transmission.
steviehype how did you solve the "Kickdown Switch/Throttle Position Sensor" problem?
