hi,
i have read previous posts which indicate that the noise may be a sticking cam follower.
when its cold it does not tick,the ticking noise seems to only start as the engine gets warm?
any thoughts? or previous experience?
thanks
I'm afraid I can't shed any light on this but I have the same problem and was wondering what the hell it is!! Every time I drive I can hear it ticking away :confused: Anyway I just thought I'd let you know your not the only one on here with the problem. I'll post any info if I do find out what it is
Check all the other posts on ticking/clattering.
Could also be vaccum drive pin.
There you go my two pence worth, they rattle and the 1.9's and 2.4's are known for them.
In the case, two 13mm nuts cover and gasket, (you need to remove the front panels and tilt the rad.
Vyper
