Been investigating knocks on the suspension and have found i have play on the tie rods. tie rod ends are needing replace but i notice the inner rod has play if you pull/push it along its length. any ideas where this play could be occurring.
just to confirm, if i pull it towards the wheel and push back into rack. would it indicate play in the rack.
ye, i understand that, which is why i asked about the play on the inner rod. does it mean the play must be within the rack or could it be in the ball joint on the inner rod.
hope to investigate this weekend.
