Hi all, just doing me head gasket AGAIN!!!
Just to check I'm doing the timing in the right order.
1. Take off rubber cap on gearbox and line up white dot with the triangle TDC
2. Set pump side of cam so slot is up the top and even with a straight edge with top of head
3. Set pump with a 13mm tube so it is near enough, then get a mate with a dti gauge and set.
4. Stick belts back on to suit.
The only thing i'm unsure about is setting the cam with the slot to the top or bottom. I know there is a proper tool but funds is tight.
Have i missed anything!!!!!I:
