tips to secure leisure battery?
718 views 1 reply 2 participants last post by  64 SPLIT
#1 ·
Does anyone know of a good method for under the drivers seat on T5? Battery is 353 wide so a little tight, but fits at the back of the base just in front of the base bolts.
Bit tricky as there's a metal join on the left had side of the base getting in the way too
#2 ·
I fitted a plywood panel across the seat base to secure the battery against the rear of the seat base, trimmed in an offcut of 4-way stretch carpet to avoid any squeaks.
I have a swivel base above it and stuck a section of foam to the underside to stop it being able to bounce upwards.
