So after two days I've just managed to get movement of the torsion bar bolts, after 5 full turns I lowered the van back down to check height and resettle. Once on the deck I heard a massive TWANG, not good. under inspection I found my NS bolt had popped out of the mount so........
I'm assuming i have too options:
1) Try and get the rest of the nut off, but its tuff as old boots!!
2) Cut the thing off and buy new?
I under the assumption that i'm going to need to refit the new or existing arm, I thinking this is a simple job??? (if anyone has already done this some guidance would be good) and then jack up the torsion bar, slide the stud through and screw on the bolt?
U can get them back in, I believe if u jak up on the wishbone then get another on the torsion bar it should go in.
wont help u with lowering again though, all u can do is apply a lot of lube & keep comin back to it!
Just pop back in use the adjusting nut to pop it back In it's not to hard don't jack on wish bones leave them hangin
that happened to me I sh*t myself!! had to use a bottle jack to push the torsion arm up enough to allow the threaded rod to be popped back in. pretty easy really.
My torsion bar poped out today I know this is an old thread ,tried the pump jack on it but undoing the shock really did help it went back in easy
