In our case, the bumper had only been trimmed a bit, which combined with the fact that towbar swivels downward a bit as it slides out, meant that it would clear the bumper. However, as you say, the internal bumper bar ~should~ be replaced - if the support bracket has been added then it will be supported OK but it will be much weaker than VW's design from the factory.I can't see how you can either remove or fit the towbar with the bumper in place unless it has been signficantly trimmed
That does surprise me.In our case, the bumper had only been trimmed a bit, which combined with the fact that towbar swivels downward a bit as it slides out, meant that it would clear the bumper. However, as you say, the internal bumper bar ~should~ be replaced - if the support bracket has been added then it will be supported OK but it will be much weaker than VW's design from the factory.
Hmmm... perhaps I'm remembering it wrong. It was exactly that type (visually) of Witter, and the bumper had less than half an inch trimmed off the bottom edge. Removing the bumper it's not a massive obstacle, though unfortunately a 2013 onward rear bumper is slightly more awkward to deal with than the earlier type...That does surprise me.
Did you have a witter bar or a different make? The Witter has long support arms that slide into box section and I just can't picture those being able to go in (or out) with the bumper in place![]()
If it were possible to do the job without taking bumper off, that would be very handy of course T:Hmmm... perhaps I'm remembering it wrong. It was exactly that type (visually) of Witter, and the bumper had less than half an inch trimmed off the bottom edge. Removing the bumper it's not a massive obstacle, though unfortunately a 2013 onward rear bumper is slightly more awkward to deal with than the earlier type...
