81 - 89 of 89 Posts
Hi, I've got a Bilbos Celeste and the offside light is almost impossible to access (god knows how I'm ever going to change a bulb).
Can the same method be used for the nearside light and are the connections a mirror image?
Just done mine, brilliantly easy peasy. I must admit I used a scotchlock for the fog but all is good...AND, following this advice I've wired in my auxiliary reversing lights on the passenger side, no snipping 馃槉 Anyone know if I can wire in a second fog light on this side too?
Tow bar is an 'Anker' sooo tempting to get the Tipex out 馃槈
Full of Cr*p....
You can fit foglights both sides.
Units are identical, so you just need another unit and the cable/connector...had one in my garage 10 years...will get it fitted one day!
So I'm guessing i can find the relevant pin on the unit and wire in direct?
OEM bayonet is ridiculously expensive and I have another i can modify 馃
Couldn't find a live for the fog on that side, guessing I'll have to run one from drivers side..
Hello
Just in the process of ordering a kit. With the wiring, do I need universal , bypass or vehicle specific. I have a T4 California
Terry
Full of Cr*p....
If you buy the "genuine" one, it's plug and play....connectors straight into the light housing.
Otherwise, you'll have to use crimps/solder for the connections...don't use "scotch cocks"....
Thanks for that, I have tried to get the vehicle specific one but it's now out of stock everywhere :-(
You can fill up the housing with Tech 7 or some other filler and they will last forever.
Mine has the original Westfalia hook and connected to the the rear of the lights with Scotch Lock snap connectors.
81 - 89 of 89 Posts
