The spare wheel shouldn't be a problem. That didn't change. The only thing may be the depth of the later bumper, as Rocketron experienced. The aftermarket ones like Towsure and Towequipe are Ok for later models and will therefore be fine for the earlier ones. May not be the same the other way round. You can get spacers to fit between the bar and the tow ball, with longer bolts, which should solve the problem, as long as it's not a 'swan neck'. T:
