Hi, new t4 owner here; '98 Caravelle 2.5tdi, 180k
When selecting reverse I'm meeting resistance, it's like there is a lip which is catching. There is no movement in the lever to push down/lift to select reverse. With a friend's help we put the bus up on a ramp and with a bit of grubbing around we replaced all the rubber balls etc in the linkage. The old ones were worn, and once assembled changing gears is noticably easier, but still meeting resistance getting reverse. There's no noise / crunching at all, just a firm clunk.
I've looked at the forums, but not noticed a similar problem to mine, just people unable to get reverse at all.
We noticed a cable fixed to the linkage, which my friend believes is usually part of the set up if you need to push (or lift) when getting reverse, except there is no movement in the gearstick when trying this. Could this cable be part of my problem? I'm trying to avoid replacing the box if possible.
Any advice out there? All other gears work fine, no noises from the gearbox, pulls well in all gears.
