Hi all,
Hope someone can help! Had the turbo hose blow off while driving on the motorway, need to order some new parts but i'm not entirely sure what they're called or the part numbers. If someone could tell me it would be greatly appreciated.
Thanks in advance.
Scott
The pipe work runs from the turbo to the intercooler, then to the EGR. The more power you're using, the higher the pressure in the pipes, that's when they'll pop. Unless you can see a problem, it's possible they weren't properly connected after being removed for any maintennance reason. The hose that goes onto the intercooler (radiator style thing at front of the van) can be a pig to get on properly.
If you've not done so already, have a close look at the connections to see how they work, and refit the pipe. The connections and clips need to be 100% in place. For a quick test, floor the accelerator in neutral to the redline, you'll know if it's on properly.
