Hi from Denmark.
I have studied turbo and turbo regulation for my VW transporter T4 2.5 TDI ACV a lot the last 2 weeks, and found the most useful information on this forum - excellent forum A:
So I will try to ask some questions here.
I have just cleaned the EGR housing and changed some vacuum and pressure hoses. Did not help. EGR valve goes from closed to open at idle and seam to work fine.
Turbo running fine. Turbo gave lots of air and pressure when I started the engine without EGR valve, inter cooler and piping and let it run at app. 3000 rpm.
Wastegate valve is closed and seam tight. Actuator don't move, and no pressure at the pressure hose, so it is not trying to either. No difference driving the car with pressure hose on or of the actuator.
Is there a limp mode on this old 1998 T4 model?
If yes, something must be telling it to go in limp mode. From reading out the ECM no error codes at all.
Or should I rather look after faults on the fuel pump? Or fuel filter?
As the turbo seam okay, I should not give up - right
