1 - 9 of 9 Posts
Hi Guys,
Been looking for ages and can't seem to find a definitive answer to this one in any previous posts.
Just need to know what tyre would be best on my standard 6Jx15 ET44 steels, with a 50mm suspension drop?
Offered up the steels with the standard 195/70/15 tyres on and seems very close to arch..
Cheers,
Chris.
Not really sure why you are suffering any issues if they are standard issue T4 wheels. I had no issues with my steels when I dropped mine 40mm. Tyres were no where near the arches (at least 10mm clearance on vertical travel) Replaced them with ET 35 7J Passat alloys with the same 195/70/15 set up and still no issues (as below) they do sit closer to the arches but loads of room.
Do you have any pic's?
Discussion Starter #6 (Edited)
Here's the current ride height on 18" RS6 replicas.
Front:
[/URL][/IMG]
Rear:
[/URL][/IMG]
The new wheels with the 195/70/15 tyres on have roughly 2cm bigger diameter..
[/URL][/IMG]
I think they'll look great once sorted..
[/URL][/IMG]
Cheers.
I've finally managed to get the van going and off the gravel to try a set of 195/70/15's and they fit fine... Wasn't what i was expecting, but I guess the offset puts them under the arch more..
My question now is how wide could i go with the tyres? Thinking 215/70/15, or is going wider on a 50mm drop a bad idea?
1 - 9 of 9 Posts
