Hi all,have a t5 130 tdi 150k,driving to work engine cuts out doing 40mph no bangs but sounded like a bike bike chain coming off unless it was engine running down,i could only just hear it,turned over but no start,a little oil in turbo hose,no mayo under oil cap,what could it be?please help!!!
We'd need much more info than you've given here to start coming up with possible solutions.
When you say ".......driving to work engine cuts out doing 40mph......" do you mean it's just done it the once & won't re-start or it always cuts out when you're doing 40mph?
Have you had any work done recently ?
Has the van been serviced regularly ?
Hi Cat3,appreciate ur help,only done it this one time,had a oil &filter change last july,1 cam sensor & turbo test,had a recon turbo before i bought it,only had it 6 months,just a couple days earlier coolant warning light came on so topped it up,&engine was slightly overheating just above 90.
I take it the engine light is not illuminated ?, but nonetheless it would make sense to get a code reader plugged in to see if there's any faults logged as not all faults illuminate the fault light.
You can buy them quite cheap, VCDS is around £250 or there the dealers who will probably charge around an hours rate, which could be £90 to plug their reader in.
Thanks m8,took it to garage today on tow,having a diagnosics done,will post the result,thanks for ur advice,fingers crossed eh!!
