21 - 40 of 111 Posts
Looking good T:
Did you notice any difference with the extra door seals?
Mine just arrived this week, hoping I haven't wasted £18 !
That’s a great van. Love what you’ve done with it. I’d replace the skylights if it were mine. Much quieter & u get more light.
Really miss my old Clubman :(
Looking for another VW coach now.
1st dibs if u ever sell the Sandhurst? T:
Discussion Starter #27
Cheers, good shout on the skylights will add that to the list
For the skylight over the cab if there is one, I’d go for a Heki (mine were 400mm square) without forced ventilation. It’s the open vents that give that wind roar above ur head. Much more streamlined too.
You kinda need forced ventilation over the gas heater & hob but not over the cab I thought. WAY quieter & much more light. T:
Discussion Starter #30 (Edited)
Was never a fan of the debadged grill and the little gap it left, so got this from travelinlite
Still not convinced on the bonnet wind deflector, can’t decide if I like it or not ?
With you on the grille. Better with VW badge.
Deflecter may save you some stone chips?
When i fitted our badgeless grille the guy across the road said " you spent all that money on a vw and then go and make it look like a Hiace" ...
What does he know Rasp: ? ...he drives a renault ....says it all I:
The deflector will save you some stone chips so personally id keep it ....but theres no harm in removing it to take a peek at without for curiosities sake ;)
Discussion Starter #38
Think I will keep the deflector for now anyway T:
Here’s a few drone shots from our fishing trip at Killin last week
Discussion Starter #40
Finally the weather to get the awning out
Then off to pendle to check out an intermittent over boost fault causing it to go into limp mode occasionally and check the quality of the previous remap
Verdict - sticking vanes in turbo likely caused by soot build up, and a remap is good, can recommend Kenny at Ecosse Tuning in Kilwinning really knowledgeable and helpful
So moneys a bit tight so going to try cleaning turbo before changing it
My garage have just purchased this week
Here's the link https://www.forteuk.co.uk/power-clean
Anyone used this system?????????
Booked in for Saturday £100 fingers crossed if not its new turbo time:bhd
