Been looking at fitting AC in the van as we're heading down to Albania/Greece in the summer and its going to be rooooasting! I figure that we could retrofit, but then we'd only be able to use it when engine is running. Best solution I can find is an under bench unit like the Dometic Freshwell 3000 or the Truma Saphir.
Both options are pretty pricey at about £1200 plus fitting... I've got budget and happy to spend it but I don't want to waste money for sake of it so want to make sure I get right kit first time!
Any thoughts on the under bench units? Any alternatives to Dometic/Truma?
I want to be able to run from AC (campsite hookup) and DC (when engines running or if stuck, run for half hour on battery). So it looks like I would also need an inverter - Dometic and Truma are both pushing their own brand at around £700 which seems crazy, I've already got a 2000W inverter so I assume I can use this? Or is there something special about their ones that goes someway to justify what they're charging?!
There are 3 air outlets so not sure how best to vent the cold air - maybe one in the cab and 2 in the rear? I assume you need to put them up high? (hot air rises, cold air falls)
Thanks! :ILU:
Thanks! :ILU:
