We're can I get work done on my gearbox, I want a longer 1st gear and better 2nd and3rd to suit the 210 BHP the van is putting out , or change diff ratio of this would work . I also would like to now we're to get heavy dutty drive shafts as iv gone throught 2 sets last year and are starting to flunk again. Any help would b gr8 lads.
Well, it would help your questions if we knew what model van you have & unless you are not making sure that the drive shafts are well greased the only way to stop the appitite for them is to stop driving it like a boy racer.
Super Moderator
Tend to agree with Brian... Bet drive shafts are going because they are not greased correctly to stop water rotting the splines. Most on here have mapped 5 pot vans and yes drive shafts are an issue but 210bhp is not a lot for some on here and its not that that kills the shafts it's the torque.
If you reinforce the driveshafts you'll probably rip the gearbox apart!
If you use a website like this in conjunction with the chassis M code sticker under your dash you should be able to find parts for you gearbox code (MQ500 type with codes KUP,MKB,MQX, PAP,PAV,PAT, PAU)....
http://www.partsbase.org/vw/transpo...afts-output-shaft-for-6-speed-manual-gearbox/
you should be able to find other vehicles fitted with MQ500 (Tiguan and Q3) gearboxes thus and pick from their ratios
http://vagfans.info/EN/audi/RDW/AQ3...hafts-output-shaft-for-6-speed-manual-gearbox
You'll probably have to buy a second hand gearbox and build a hybrid and you could stick one of these in too
http://garagemidnight.com/products/wavetrac-oa6-mq500-2wd-differential
