can anyone assist me as I'm struggling to get the replacement 1y to fire,everythings done now and this is the last bit, It cranks great oil light out straight away but won't fire. I have loosened the 2 fuel pipe unions on the pump but there is no fuel there,can anyone advise me on how to bleed the fuel system on a Bosch pump'd 1y
did you fit the pump off your old van or is this one from the donor ??
if its from the donor it may have the immob chip fitted.
its the donor engine & pump, but I couldn't see any immobilser on it, just the 1 terminal like the original pump had
whats the immobilser look like
still no joy, the fuel filter is the sealed type with the pipes in the top and that valve thingie,
I have had to blank of a t- of the fuel line into the filter as the 1y bleed off pipe goes into the pump and not back to the filter as in the 1x, but i am getting nothing. there is about 6inches worth of fuel you can in the fuel line but that doen't move not even squirting brake cleaner down the inlet manifold and cranking
any advice greatly appreciated
turns out the pump that came with the motor is knackered :* gotta change to my old pump - this things gunna see me off :(
