previously known as: baggit
Steering wheel off and all going well to fit the mfsw, I need to check what the j285 control unit is, can't progress without being sure ?
Any help would be be appreciated
Thats the steering column control unit isn't it? Usually bolted on the bottom side of the column but if you let me know what van your working on I will check for you.
Here's the instructions I was given
here mate:
There are three missing wires for the MFD that go from the
F138 - Airbag coil connector and return ring with slip ring (grey multiplug for stalks, ect ect)
to
J285 - Control unit in dash panel (speedo)
Stalk------------------- Speedo
PIN 24 goes to pin 21 (MFA+)
Pin 23 goes to Pin 22 (MFA-)
Pin 18 Goes to Pin 23 (MFA-R)
Aha didnt take it literal enough, it really is the speedo, the connector at the back
