i may have got the complete wrong end of the stick here but does the volvo v70 tdi engine fit into a t4? if so, how much of a ball ache would it be to do?
I was at my local diesel specialist and one of the guys who works there said that he had a V70 with the same engine in, he said that the injectors from the v70 would be a good upgrade, haven't foudn any other information about it on the Net though, i was thinking about buying a spare engine to refurb and then poss fit over the winter as mine is a little tired but can't seem to find a match and don't have the Volvo engine code, will update you if i find anything more :)
having just done my belt change using the volvo workshop manual the 2 are pretty much the same, the t4 has a diff sump as it sits at more of an angle, the fuel pump is sited higher on the volvo and looks like may need to swap some bts off t4 pump. plus i suspect you will need a custom remap for the volvo setup. but it looks doable if my engine had turned out to be dead i was going down this road T:
