Hi Guys,
My van broke it's cambelt a few months ago and got it working again, after some serious cash!!! Since then the van has been a bit under powered, not very noticeable with normal driving conditions, but got a big freight a couple of weeks ago when towing a caravan and lost power on the hills!! So the searching began for this powerloss!
Some hoses from the turbo to the intake was leaking where the orriginal VW clamps was still in place, replaced it and it did make a differance but still not as before the cambelt. While doing all of this I decided to blank the EGR and replaced all the vacuum hoses, and clean the pipes and intercooler out, which had some oil in, not much, but noticeable!!
When I started with the vacuum hoses I realized that the plumbing was all wrong on the N75 valve, thus the major problem with the van being underpowered!!!!!!!! My question though is does anybody know where all the pipes go from and to the N18 valve?
Also the O-ring at the turbo inlet was so worn the pipe just fell of when I removed the bolt, thus sucking un-metered air in. My turbo also have a bit of play on the shaft on the inlet side, not much, but it is there. So now I need to rebuild the turbo also. Better to do it now then to replace the whole lot later on after it blew up!!
Thanks to the guys who posted a LOT of articles in the technical articles that helped me so much!!!!!!!!!!!!!!!
Thanks in advance for the help!!!!!!!
