I've just done a repair on my ticking vac pump (Pierburg pump on a 2.5tdi, 2002 ), I drained the oil from the pump and replaced the small piston rod oil seal with a new one, as described in 'Vacuum Pump Strip down and fix' thread
I took the van for a 3 mile run and the pump works much better now, with no tapping and also more vacuumT:
But I have noticed that now the pump gets really hot; after the run I could just about touch it, but it was close to burning me.:eek:
I didn't do the 'finger temperature test' before I fixed the pump and now I don't know if this is normal or not. I'm thinking that if the new oil seal prevents any oil entering the piston chamber then how does it get lubricated? I did smear some light oil around the piston before I reassembled but I'm not sure if this enough to keep it moving and greased.
Has anyone got any ideas on this, am I being paranoid or could the pump be overheating and then fail? Can someone please touch their pump,(ooh err) and let me know how hot it gets.
thanks
Literally, white van man
Just driven 90 miles at mixed speed, last 30 at 70mph, my vac pump is very hot, touch it and no burn but I wouldn't like to press my finger on it.
It is bolted to the block when all said and done, and that is hot too I:
Hope this helps T:
Chris
