Clutching at straws here now.
05t5 t28.
Speedo sits well below the zero when off and stays there when starting up.
When moving seems to hold itself 10mph below my actual speed.
Almost like it has started low and moves from the wrong zero.
Had dials out n tried moving needle but always settles back to below ground zero.
Can a vagcom tweak help?
Should I try another cluster?
Are any others compatible, ie passat?
Please help! Driving me nuts.
Super Moderator
You can test the speedo via instruments on the control panel in vagcom. Don't know if it can be reset but is there not a stop at the zero :*
Discussion Starter #4 (Edited)
Cheers Festa. Is a weird one.
After I moved it to zero then plugged it in it just paused a while then stepped back down to as low as it could go.
Prob need a new cluster, at least to see, as there are never any T5's breaking, anyone know if anything else is compatible?
Sits as far as I can judge with the needle 10-12 mph below gps at all speeds.
