Hi all. Once again my van has got me stumped. I've done the PP mods and am getting 150hp after Wayne remapped it. I noticed afterwards there was a vibration or judder when under load at about 2000rpm. The higher the gear then the worse it was.
Then the clutch started slipping and the vibration went.
However, now I've changed the DMF and clutch and eliminated the clutch slip, the viration has returned. I was hoping it was because the DMF was completly knackered but this was not the case. It is only under accelaration about 1800 to 2200rpm, just as the turbo is giving it all.
Any help or ideas would be appreciated. Thanks.
jabby fingered, worn nubbed, ginger ninja
I had a similar problem on my works transit recently and it turned out to be a knackered drive shaftT:
