Victron Products Now In Stock at 12 Volt Planet
We're now able to supply the full range of high quality Victron power management products including pure sine wave inverters, multi-stage battery chargers, solar charge controllers (PWM and MPPT), solar panels and kits, voltage sensitive relays, battery monitors and much more. Check out the Victron website for their full range.
We are currently stocking Blue Power multi-stage battery chargers, Phoenix pure sine wave inverters, BlueSolar rigid solar panel kits and the Cyrix-ct 120A voltage sensitive relay as standard, but we're adding more items all the time and can supply any Victron product to order so please just ask.
Blue Power Battery Chargers
  • Professional quality chargers
  • Multi-stage with adaptive charging technology
  • High efficiency and low heat output
  • Multiple protection features
  • LED charging status
  • Silent operation
  • 10A, 15A and 30A models available (also 30A with twin output for 2 batteries)
Phoenix Inverters
  • Pure sine wave output (can power all types of mains appliance)
  • SinusMax hybrid HF technology for high efficiency
  • Designed for professional duty
  • High start-up power
  • Remote switching facility
  • LED fault diagnosis
  • Auto-shut down on low battery voltage
  • 180W, 350W, 800W & 1200W outputs
Rigid Solar Panel Kits
Complete installation kits:
  • High performance Victron BlueSolar polycrystalline solar panel housed in aluminium frame
  • Waterproof twin cable gland
  • 5m of 4mm2 solar cable
  • ABS panel mounting brackets and sikaflex adhesive
  • Victron PWM charge controller (in either single or twin output models, for charging 1 or 2 batteries)
  • 50W, 80W, 100W & 140W panels available
Cyrix-ct Voltage Sensitive Relay (Battery Combiner)
  • 120A, 12/24V (auto-ranging)
  • Intelligent trending software to determine connect/disconnect (eliminates 'chatter')
  • Dual sensing (senses voltage on both sides of relay)
  • Over-current and over-temp protection
  • Emergency start-assist
Prices and further details are on our website and if you any questions please don't hesitate to give us a call to discuss.
Paul
