I've got no reading of temperature on my 1997 1.9td, I have checked the sensor which I think works as I tested with a multimeter on pins 1 and 4 with the engine cold I get high resistance and when hot it shows low resistance I am assuming its the dash problem however I can only find the guide for repairing the aunlouge dash and not the digital dash I have, is the voltage regulator the same and is this likely to be the problem?
