1 - 13 of 13 Posts
Evening all,
My clutch is on its last legs and in need of replacement ASAP I:
Having started down the Projekt Proper Job route, I need to get something a little more substantial to deal with the extra power T:
I know people have done away with the dual mass flywheel and put the VR6 clutch in, what I need to know is what flywheel was used :confused:
Is it the 2.4d flywheel? It needs to support a 228mm clutch ;)
Any help or guidance would be really appreciated A:
Thanks everyone
Chris :ILU:
g60 flywheel or tdi flywheel are 228mm instead of the abl's 220mm. and a vr6, tdi or g60 clutch will fit the 228mm flywheel.
im going to be running a g60 flywheel on my TDi 1.9, with g60 clutch
Thanks Rixy T:
Will pass that info on 2 my main man in the know......coz it means naff all 2 me :eek::D
Appreciate the info fella A:
Chris :ILU:
Meithered to death
Yea yea i have fitted VR6 clutch and G60 flywheel last wednesday but the G60 flywheel has six bolts to secure it to the 1.9 4 cylinder crank so it wont fit onto a 2.5 5 cylinder crank because they have 8 bolts,VR6 flywheel has 10 bolts so thats not an option either.
2.4D have 8 bolts and solid flywheel but i dont know the clutch diameter it could be 220mm or 228mm or maybe a completely different size. I am investigating the options!
Will more than likely be looking at a new cutch this summer some time, would be interested in these options aggiet4, and prices etc. as I may find myself doing some Cornish/Swedish tuning after the summer :D
Meithered to death
Investigation over and i have discovered that the 2.4D up to 1996 has an 8 bolt solid flywheel with a 228mm clutch.
Also the 5 cylinder petrol T4 has an 8 bolt solid flywheel with a 228mm clutch.
So Chris you need one of these flywheels and i would opt for an upgraded VR6 clutch and not a standard one because when your Projekt proper job is complete my ansome you will be making way more torque than a standard VR6 clutch can cope withT:
gettin there DRECKLY my lover:cool:
meatholes:ILU:
Discussion Starter · #11 ·
meatholes:ILU:
I is gonna give u 10 dolla worth of reach around Sweat cheeks :D
Will bell ya 2moro long dong T:
Sorry , me being a complete dullard there, totally forgot you had changed your engine!!
One guiness too many, I will retire to bed and sleep easy now that the puzzle is solved without my rambling
T:
1 - 13 of 13 Posts
