1 - 9 of 9 Posts
Hi all does anyone have a picture of where the 2.4D Injector hard line goes from the pump to the injectors? Thanks
Hmm unless I'm searching the wrong things I cannot find anything conclusive anywhere. These 2.4Ds seem to be a little elusive on info.
Discussion Starter · #4 · (Edited)
Anyone? I just need to check I've reconnected back up in the correct firing order.
Here's what I have:
193079
193080
1 goes to the port next to the allan bolt. 2 follows after then 4 and 5 and finally 3. All in a clockwise fashion as you look at where they connect to the pump (anti clockwise from belt side).
Full of Cr*p....
Unless you've bent them, they should only fit in one place.
If you have to strain to connect, they're wrong.
Yes they were horribly bent when the cylinder head was removed. This is why I am unsure if they are back to their original position. Ive had to manipulate them a fair bit to get them to reflect a standard fitting order. As the pump is rotary i have connected them 1,2,4,5,3 but ultimately i am unsure if i have the starting point correct.
I don't know how badly bent they could have gotten to make it impossible to check - I guess you haven't tried to start the motor yet (?)
Anyway, maybe you can compare this image with what you've got, though clearly and obviously it's not as clear nor as obvious as you'd like . . . .
193435
BTW: You do know that you can resize your images after you've pasted them. I'm reading this on a laptop and full-size images scream at the reader.
Discussion Starter · #9 ·
Cheers chap. As you say it's not the clearest it could be but in all honesty I can't see how I could have gotten it wrong.
Yes, the pipes were bent up to hell - seriously bent. I have tried to start it but it won't idle and kicks out unburnt white smoke diesel so I'm just trying to rule out incorrect connections.
1 - 9 of 9 Posts
