I have sort of a double problem :)
Today when i was crusing in my transporter 1,9 TD suddenly my generator lamp started to flicker, then after 20 kilometers the oil lamp started to blink/flash, even though i had enough oil in the engine.
I know that i need to replace my glow plugs but i can´t imagine that they are the problem.
Can a bad generator generate this problem?
Best regards
Nicklas
Check your alternator belt if that is worn / slipping your oil light and battery light will be flashing. Sometimes the pully wheels seize causing belt to snap. Not a major job if you get them in time.
