just wondering if anyone can help i have a vw t4 special its on a 1996 p reg its a 1.9 diesal swb and its as flat as a fart is there any way of uping the performance or is there a good engine that i could put in that would make it go really well please help jas
check you accelerator cable isnt knackered, engine off get somebody to press pedal to floor, look under bonnet to see if the throttle lever on the fuel pump is going all the way to the stop.
mine was slow when i got it only had 3/4 throttle.
they aint that fast tbh anyway
are you a TD model - if so turbo and fuel pump can be tweaked - simple, cheap effective T:
otherwise a 1.9 TDi swap is the way to go :ILU:
either way, plenty of threads here for you to read up
