1 - 10 of 10 Posts
I have noticed recently that my 1998 1.9tdi (professional conversion) seems a little down on power? I have a quality boost gauge fitted and normally (before the power loss) when the turbo goes to full boost it shows about 17 psi and then this backs off to about 15 psi. The gauge doesn't do this anymore and the turbo goes up to just under 15 psi but not beyond. All hoses seem good? Any thoughts?
have you scanned for fault codes?
so, have you now got a copy of vcds & lead or a generic code-reader?
Rich.
Hi there and thank you for your reply. I have a lead and it came with a CD which I bought off ebay months ago. On the lead it says KKL Vag-COM. I haven't installed it yet on my laptop yet. Is this straightforward? Is it easy to use?
Full of Cr*p....
Better to download the software direct from RossTech...FREE. (And latest version.)
If you want to do timing though, you'll need to pay the $99 fee to register it.
It's the same software on your CD....3rd party can copy and then "SELL" it, but you still need to register for the full functions.
can you give a rough idea of cost and recommendation of who did the conversion ? it something I have been thinking of doing......
Hi there. Mine was done about 8 years ago by MV Engineering in Telford. Highly recommended. They have a Facebook page.
I now have VAG com on my laptop and the correct lead. Can anyone explain what I have to do? Is it self explanatory? I guess the engine has to be running to pick up any faults? Is there a guide how to do this?
Connect the lead to your diagnostics port on the van, (should be under the dash, driver's side, just above the throttle pedal).
Connect to your laptop, power up the laptop. Switch your ignition ON, but do not start the engine. Double click the VCDS icon on your desktop.
You ideally need to enter your vehicle type, (which will be a series of letters/numbers. These are part of your chassis number.).
VCDS will then ask if you want to auto scan, (or something like that, it's a while since I last used VCDS). Just let it auto scan, which takes around 5 minutes ish.
Best thing really is to go on the Ross Tech website & read the online manual. If it's the first time you have used/connected VCDS to your van there's a few steps you need to complete before you scan it, but it's all very straight forward.
Full of Cr*p....
Read The Manual....1st step.
Not sure where you're OBDII port is.....under the steering shroud on mine.
Connect it up, boot the laptop, when you have VCDS running, turn on the ignition.
Select a coms port (1-4) and try each one until you get a connection.
After that.....follow the on-screen intructions.......and get lost!?!?!?
Back to the manual.....
Also note, better readings are obtained when the engine is up to temp.
If you want to do timing checks, you'll have to pay the $99 to register it.....the best money I ever spent!
Read the online manual.....and then again......print it out if you can (preferably at work using their ink/paper....oops), but either way, it's worth it.
Worth more than reading whatever cr*p or anyone else comes out with anyway regarding this wonderful bit of kit.....we all have different ideas about how to use it.....and never remember what we did the last time!!!! (At least I don't :eek: )
Discussion Starter #10 (Edited)
Hello guys. Thank you for all the replies to this post and sorry for my late reply. I have only just tried using this and could not get it to work. I purchased the lead off Ebay ages ago and it came with an install disc with VAGKKL 409.1 on it. I did as instructed and it found the right port but the program kept shutting down. I have deleted this program from my laptop and I have now down loaded VCDS Lite from the Ross Tech website. I downloaded the program designed for 3rd party interfaces. Connected it up and it all worked but at the end I wasn't able to copy the code?. From memory there were 5 fault codes and I think one was 00265 for the exhaust recirculation valve (EGR)? This has been disabled on my van. For the other codes it said I had to register/activate? I don't really want to pay out 99 dollars for this. Is there anything else I can do?
1 - 10 of 10 Posts
